AAA authorization and shell cmd sets
dalehooser
Hello, Iam new to the group. I have looked around and found some reference to my problem but no clear answer so I thought I would post here.
I have ACS 4.2 that is serving as my tacacs+ server for router and switch access.  I am using windows AD for password authentication.  My authentication is working but I am a bit confused on command authorization.
In global config I have
aaa new-model
aaa authentication login <name> group tacacs+ local
aaa authorization config-commands
aaa authorization exec <name> group tacacs + local
aaa authorization commands 15 <name> group tacacs+ local
aaa accountign exec <name> start-stop group tacacs+
aaa accounting commands 15 <name> start-stop group tacacs+
In VTY config I have
login authenticaion <name>
In ACS I have groups set up and my users are are configured to use the group setting. The privilge level for the group is 3
For help desk staff I need them to be able to run the sho config command.  I created a command set list with the proper command and argument in place.
The issue is that when logged in to the devices via ssh  to vty x as the help desk user and I try and run the sho config it uses the priv level and denies the command locally.  I have verified by running debug the aaa server is not being queried for the authorization. How do I get the router/switch to go to my aaa server for any command about the assigned priv level?  For my net admins with a priv level of 15 set in the ACS group the AAA server is queried so I am a bit confused and expect I missed a simple step in the config.
Richard Burts
Dale
I hope that I have the correct understanding of your situation. You have some users who are configured to be at privilege level 15 and their use of commands is correctly authorized but users who are configured to be at privilege level 3 are not authorized. To solve this try using the command:
aaa authorization commands 3 group tacacs+ local
Rick
Rick
