aaa authorization with Tacacs+
mohammed hurais
Hello All,
I am trying to figure out how aaa authorization with tacacs+ works.
I am totally comfortable with aaa authentication..But am not able to understand how it works...How diff priv levels are assigned to diff users?..
I am totally freaked out...
mohammed hurais
how can we apply diff priv levels for diff users using AAA authorization?
The device side side setup is pretty simple. You just use the aaa authorization command set. A good bit of the setup is on the ACS server end.
Cisco has a pretty thorough configuration example posted here.
