About Cisco stackwise and rmon
cn1by080byj
We want to setup rmon function on cisco stackwise devices ports.such as collision,CRC align error.Is is possible
Joe Clarke
I'm not sure if this is possible, and I don't have a stack readily available for testing. However, I think it should work as the stackwise port does show up in the ifTable. The command to use to enable RMON etherstats collection is:
rmon collection stats 1 owner "user"
If the command works, you should be able to poll the RMON-MIB to get the stats information for this port.
