About CM
robin_goel
I am using LMS 2.5 and Campus manager 4.0.3. it is a very silly question. But plz tell me, i wanna to see my current host in network. As i refresh host anytime and i can see full list of hosts which r active in my network.
miheg
Level 9
Level 9
Campus only shows the discovered network devices like routers switches accesspoints etc.
I shows their status as green or red based on the result of the last data collection.
This means it could be status of an hour ago.
Depends on how ofter you let campus do a collection.
if by refresh you mean running a datacollection then yes it shows you the status of that collection.
Cheers,
Michel
Thnaks, I had got solution as i can get it from user tracking and apply the filter.
anyways thanx for supporting yes that is also way.
