cisco switches with Fluke Optiview Console 7.0
hagirebench
hi. i'm trying to run fluke optiview console 7.0 with the cisco swithces (4503,2950 and 3560)(multiple vlans) i've managed to make the SNMP funtional, but can't seem to make the RMON work.
is there any command issued on the switch to make the RMON work.
if there is someone familiar with fluke software running on cisco device i surely need your help
thnx,
ben
David Stanford
What are you trying to do with RMON? Are you trying to poll objects from the RMON-MIB or are you configuring rmon alarms and events?
What does your RMON config look like?
hi david,
i'm tryning to make the cisco switch a RMON device for the Fluke Software. it dosent say in the manual of the Fluke software what to activate to make the switch(cisco) a RMON device. they say that for HP switch, it is capable of being a RMON device for Fluke. Is it possible for cisco switch to be a RMON device in Fluke Optiview Console 7.0? or i need to have some IOS upgrade for it to work??
Switch IOS are:
4503 - (cat4000-I9K91S-M), Version 12.2(25)EWA4, RELEASE SOFTWARE (fc1)
3560 - c3560-ipbase-mz.122-25.SEB4
2950 - c2950-i6q4l2-mz.121-22.EA4a
i have NO RMON configuration yet.
rgds,
ben
