about ObjectID of CISCO-MEMORY-POOL-MIB
hsasaki_cert
I had some question about "CISCO-MEMORY-POOL-MIB"
Achieve Optimal Routing and Reduce BGP Memory Consumption
R1# show processes memory | begin BGP
PID TTY Allocated Freed Holding Getbufs Retbufs Process
73 0 678981156 89816736 70811036 0 0 BGP Router
74 0 2968320 419750112 61388 1327064 832 BGP I/O
75 0 0 8270540 9824 0 0 BGP Scanner
70882248 Total BGP
77465892 Total all processes
http://www.cisco.com/warp/public/459/41.html#bgpreceivedtable
> 70882248 Total BGP
The method of calculating "70882248"?
Which objectID of CISCO-MEMORY-POOL-MIB is used and is calculated?
smahbub
Level 6
Level 6
think its the ciscoMemoryPoolUsed object used to calculated the total BGP processes
