ACL ASA - Deny/allow policies - Packet tracer 8.2
Brahim O
Hi team,
I'am facing an issue related to ACLs on my ASA configuration, I have an ASA conncted to 3 networks :
- OUTSIDE, DMZ, INSIDE.
My inside network is subnetted on 3 network/vlans.
I have to setup some ACL to matche the following requirement :
- Configure an ACL to block PINGs to the server google from VLAN X and VLAN Y
- Configure an access control list to block the FTP connection for the network VLAN X to web server
- Configure an access control list to allow PING requests from the WEB server to the printers.
I tried some ACL configuration but i cant figure out why its not working:
ASA(config)#access-list ACL_No_ICMP_VlanX-Y_To_Google extended deny icmp 192.168.1.0 255.255.255.192 host 64.100.100.2
ASA(config)#access-list ACL_No_ICMP_VlanX-Y_To_Google extended deny icmp 192.168.1.64 255.255.255.192 host 64.100.100.2
ASA(config)#access-list ACL_No_ICMP_VlanX-Y_To_Google extended permit icmp any any
13 Replies 13
all config is prefect except you not apply ACL to interface.
Brahim O
I also tried the following but the ping is still allowed from inside VLANs to Outside :
object network Outside_To_Inside_WebServer
 host 192.168.2.10
 nat (DMZ,PUBLIC) static 88.40.12.2
object network VLAN-X
 subnet 192.168.1.0 255.255.255.192
 nat (INTERNAL,PUBLIC) dynamic interface
object network VLAN-Y
 subnet 192.168.1.64 255.255.255.192
object network VLAN-Z
 subnet 192.168.1.128 255.255.255.192
route PUBLIC 0.0.0.0 0.0.0.0 88.40.12.1 1
access-list Outside_To_Inside_WebServer extended permit tcp any host 192.168.2.10 eq www
access-list 101 extended permit ip any any
access-list 101 extended deny icmp 192.168.1.0 255.255.255.192 host 64.100.100.2 echo
access-list 101 extended deny icmp 192.168.1.0 255.255.255.192 host 64.100.100.2 echo-reply
access-list 101 extended deny icmp 192.168.1.0 255.255.255.192 host 64.100.100.2 unreachable
access-group 101 in interface PUBLIC
aaa authentication ssh console LOCAL
Thanks for your time!
Hi sir ! Thank you !
My question is on what interface should i apply that acl ? Public right ?
As the goal is to block ping from 2 inside vlans to the Google server
64.100.100.2 ?
How I can apply that policy actually ?
Sorry for that question that seems to be obvious but I am a noob on asa
firewall.
Kind regards
This linr i think issue
Show access list
Check if permit any any is above other deny line
Sure ! Let me check and i ll get back to you !
Kind regards
Hi MHM,
Here is my show access-list result :
ASA(config)# show access-list
access-list cached ACL log flows: total 0, denied 0 (deny-flow-max 4096) alert-interval 300
access-list Outside_To_Inside_WebServer; 2 elements; name hash: 0x141ed242
access-list Outside_To_Inside_WebServer line 1 extended permit icmp any host 88.40.12.2(hitcnt=0) 0x23b08668
access-list Outside_To_Inside_WebServer line 2 extended permit tcp any host 192.168.2.10 eq www(hitcnt=0) 0x872cbe53
access-list icmp_deny_vlanxy; 3 elements; name hash: 0x9b7e1e5c
access-list icmp_deny_vlanxy line 1 extended deny icmp 192.168.1.0 255.255.255.192 host 64.100.100.2(hitcnt=0) 0x78b47b96
access-list icmp_deny_vlanxy line 2 extended deny icmp 192.168.1.64 255.255.255.192 host 64.100.100.2(hitcnt=0) 0xe3886deb
access-list icmp_deny_vlanxy line 3 extended permit icmp any any(hitcnt=0) 0x9d3190d0
ASA(config)#
Even after that the ping is still allowed from internal VLAN to outside, i mean google server : 64.100.100.2
Here is my current configuration. i did some changes, but anyway i dont know how to setup the first policy to deny ping from vlanx et and y to the google server ...
ASA(config)#show run
: Saved
ASA Version 9.6(1)
hostname ASA
domain-name span.com
enable password Qa8ENuiyPgE/u.0d encrypted
names
interface GigabitEthernet1/1
 nameif INTERNAL
 security-level 100
 ip address 192.168.1.194 255.255.255.192
interface GigabitEthernet1/2
 nameif DMZ
 security-level 50
 ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet1/3
 nameif PUBLIC
 security-level 0
 ip address 88.40.12.2 255.255.255.252
object network DMZ-SERVER
 host 192.168.2.10
object network INTERNAL
 subnet 192.168.1.0 255.255.255.0
access-list OUTSIDE-DMZ extended permit icmp any host 88.40.12.2
access-list OUTSIDE-DMZ extended permit tcp any host 192.168.2.10 eq www
access-group OUTSIDE-DMZ in interface PUBLIC
username admin password Qa8ENuiyPgE/u.0d encrypted
username carlos password Qa8ENuiyPgE/u.0d encrypted
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect tftp
service-policy global_policy global
telnet timeout 5
ssh 192.168.1.128 255.255.255.192 INTERNAL
ssh 64.100.100.3 255.255.255.255 PUBLIC
ssh timeout 5
router ospf 1
 router-id 9.9.9.9
 log-adjacency-changes
 network 192.168.1.192 255.255.255.192 area 10
 network 88.40.12.0 255.255.255.252 area 10
 network 192.168.2.0 255.255.255.0 area 10
 default-information originate
ASA(config)#
Done for tonight, lets continue tomorrow.
I read that documentation also :
https://www.doncrawley.com/soundtraining.net/files/fundamentalsofciscoasasecurityapplianceaccesscontrollists_r2.pdf
But no chance yet ! I tried a config and all my asa network port went down
Hi MHM, after trying several time to find solution, unfortunately anything seems to work as expected.
For thoses who want to have a look on the pkt file let me know.
Hi team, anyone please ?
i have my exam in 2 days, i could appreciate some help before. Thank you
can you share the PKT file, let me make double check
Hi MHM, here you are! thank you.
enable pass are cisco or class just try both.
Please also note that there is a bug with the inspect icmp that is not permanent. Each time you restart the ASA you have to re-enter the setup like following :
#Inspect ICMP on ASA :
configure terminal
NO policy-map global_policy
exit
configure terminal
  inspect ftp
  inspect tftp
  inspect icmp
exit
write memory
#Appy the policy again after recrating it :
configure terminal
no service-policy global_policy global
Here are the pain point for me, i cant figure out how to address them, i spent hours and hours just for the 1rst one with no success.
- Configure an access control list to block PINGs to the server google from VLAN X and VLAN Y
Thanks you !
I know that there are many bug in PKT, even if you sure 100% your config correct the bug is unpredictable.
anyway
I see attach PKT file and but I dont see it ?
