ACL configure
cyberpea
I want to create an ACL on Cisco to prevent one network from communicating with others except for the internet. Can you help?
Ruben Cocheno
@cyberpea
Have Extend ACL and allow only what you need
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
Ruben Cocheno
@cyberpea
I think you can I depend
you can try use
deny <LAN><LAN>
permit<LAN><Any>
the ACL apply IN direction
MHM
Blue_Bird
Hello cyberpea,
You can achieve this by configuring an Extended ACL...
Here is the sample configuration....
Note:-   RFC 1918  means Private IP Address
Router(config)# ip access-list extended INTFILT
Router(config-ext-nacl)# permit  tcp   any   any  established
Router(config-ext-nacl)# permit tcp   any 130.13.150.223  0.0.0.0  eq  80
Router(config-ext-nacl)# permit tcp   any 130.13.150.223  0.0.0.0  eq  443
Router(config-ext-nacl)# deny  ip  10.0.0.0    0.255.255.255   any
Router(config-ext-nacl)# deny   ip   172.16.0.0    0.15.255.255   any
Router(config-ext-nacl)# deny   ip   10.0.0.0    0.0.255.255   any
Router(config-ext-nacl)# exit
Router(config)# Interface   serial  0/1
Router(config-if)#  ip access-group   INTFILT  in
 Best regards
******* If This Helps, Please Rate *******
Where the inter-VLAN is happening? on a switch, a router, or a firewall? are you trying to deny a subnet from talking to other subnets in your network allowing internet? or are you trying to deny traffic between the same endpoints in the same subnet allowing internet?
