About Setting Up CBX151AX
Translator
Community Manager
Community Manager
Having tried to register the MAC address on the website, the LED on the device is still flashing blue.
Mark Elsen
      - Note that the device may need a DHCP server to obtain an address on initial setup , (which can be changed afterwards)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
KJK99
Level 3
Level 3
Use one of the supported setup methods as per the AP administration guide.
"The initial setup of the CBW AP can be performed using one of the following methods:
• Through the Primary AP Setup Wizard and over Wi-Fi.
• Use the Cisco Business Mobile app.
• Use Network Plug n Play via Cisco Business Dashboard application."
Kris K
