ACS integration problem
I want to integrate CWLMS 3.1 under Solaris10, with ACS 4.2 but I can´t do it.
Because when I fill the data , then I get the "AAA Client: Not Configured"
Why? What is missing or wrong?
Please, any ideas?
Thanks very much in advance
Joe Clarke
Is the LMS server an ACS client?  If so, check the ACS configuration to make sure that all TCP ports are open for administration under Administration Control > Access Policy.
Hi Joe
Please tell me how  I know if "Is the LMS server an ACS client?"
How verify this?
Thanks very much!
This is done under Network Configuration in ACS.  The LMS server must be added to one of the NDGs.  You must add all IPs of the LMS server here.
