Hey folks!
I've noticed a problem I'm assuming is related to ACS.
I normally open up a continuous ping to a router when I reload it so I know when it's back up.
Normally, once I can ping it, I can ssh into it.
Now, when I can ping it, I have to wait a good five minutes before it'll accept my login credentials.
Router is using ACS for TACACs authentication.
I know the connectivity is good, because I can ssh to switches behind the router at the site. It's just the router that won't accept my login/pass for a few minutes.
I know it's ACS related, but I'm not sure what it is.
Has anyone else seen this?
Running ACS v4.2
Thanks in advance!
Ven
Hi Ven,
I am not an ACS expert , however I would suggest is to look at the failed attempts logs and check if you found anything
useful.
Thanks-
Afroz
[Do rate the useful post]
****Ratings Encourages Contributors ****
Hi Ven
I doubt it's related to the ACS.
IOS holds down authentications/logins after a reload to make sure the network is properly converged to be able to write accounting logs when configured so.
Try to issue the following command:
no aaa accounting system guarantee-first
This instructs the IOS not to wait for the network to converge for accounting to work.
Roberto
