06-17-2015 06:15 AM
I have simple EEM applet policy which runs every 10 mins and executes tcl script.
event manager applet testconnection
event timer cron cron-entry "*/10 * * * *" maxrun 60
action 010 cli command "enable"
action 020 cli command "tclsh flash:TestConnection.tcl"
All works fine but in the end I get message : tty is now going through its death sequence
029213: Jun 17 12:50:30.262: %HA_EM-6-LOG: testconnection : DEBUG(cli_lib) : : OUT :
029214: Jun 17 12:50:30.262: %HA_EM-6-LOG: testconnection : DEBUG(cli_lib) : : OUT : 08-isr-1#
029215: Jun 17 12:50:30.262: %HA_EM-6-LOG: testconnection : DEBUG(cli_lib) : : CTL : cli_close called.
029216: Jun 17 12:50:30.262:
029217: Jun 17 12:50:30.262: tty is now going through its death sequence
It seems like EEM is ending abruptly. Do I need to do something for the EEM to end gracefully after finished?
its ISR 3945e with IOS 15.3.2.T2
06-22-2015 04:24 PM
This message is fine. You only see it because you have debugging enabled. That said, you should not be using EEM to spawn a tclsh script. That is inefficient. It would be better to convert the tclsh script to an EEM Tcl policy, and then register that instead of the applet. This way you are not involving an unneeded subsystem.
06-23-2015 07:09 AM
Thanks Jospeh,
Can you please guide me on how to convert tcl script to EEM tcl Policy.
tcl script just checks connection to web servers and update IP host entries based on live servers.
06-23-2015 07:12 AM
Without seeing the script, I cannot comment on everything that must be done to convert it to EEM Tcl. But in general, have a look at http://www.cisco.com/c/en/us/td/docs/ios/netmgmt/configuration/guide/12_2sx/nm_12_2sx_book/nm_eem_policy_tcl.html .
