ACS with TACACS Error in CiscoWorks
jjt75
I am running CW on 2003 server and everytime I try to enter it into ACS, everything works fine, until I restare the daemon engine, then I (with full admin rights) gets locked out. WHat gives???
nhabib
Level 9
Level 9
Make sure that you have the System Identity User in ACS with full access to CiscoWorks applications.
I believe detailed information is available in the CiscoWorks Common Services 3.0 White Paper located at:
http://www.cisco.com/en/US/products/sw/cscowork/ps2425/prod_white_papers_list.html
