Add exception in a Pix Asa 5505
Hi to all.    I hope to be on the right place
I'm as rookie as posible in asa 5505 and my english is as bad as possible
I want to allow an internal server with IP 192.168.1.5 to "comunicate" with IP 192.168.5.82 in port 500
To be more clear.
When i type telnet from 192.168.5.82 to 192.168.1.5 in port 500 i receive a black screen so logical all is ok.
When i type telnet from 192.168.1.5 to 192.168.5.82 in port 500 said unable to connect
Can anyone tell me as detail as possible what command i have to add.
Thanks for your time.
JEFF SPRADLING
Vagelis,
First, this question is better suited for the security / firewalling forum (https://supportforums.cisco.com/community/5966/firewalling), but no worries.
Assuming the two networks are separated by the firewall, you will need to add a rule that allows telnet from 192.168.1.5 to 192.168.5.82.
If you want detail, you will need to post your config so we can give you the exact command to run.  Be sure to remove sensitive information (public IP Addresses, SNMP Communities, pre-shared keys, passwords, etc.) before posting.
Jeff
