Add Public Server Problem
AntonioFerrara75252
Frequent Visitor
Frequent Visitor
I'm a beginner with firewall management so I apologize in advance.
I have an ASA5506-X firewall and am trying to add Public Server.
In ASDM I used the menu:
Configuration -> Firewall -> Public Server
I have used this configuration
But I have this error:
this is the configuration:
Result of the command: "write terminal"
: Saved
: Serial Number: JAD23491DFL
: Hardware:   ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.8(2)
hostname ciscoasa
enable password $sha512$5000$mfUNWUnmc9qKcbjHg8oHaw==$OEVZzWm+5Cbcdz9D9NMsLg== pbkdf2
names
interface GigabitEthernet1/1
 nameif outside
 security-level 0
 ip address dhcp setroute
interface GigabitEthernet1/2
 bridge-group 2
 nameif inside_1
 security-level 100
interface GigabitEthernet1/3
 bridge-group 1
 nameif inside_2
 security-level 100
interface GigabitEthernet1/4
 bridge-group 1
 nameif inside_3
 security-level 100
interface GigabitEthernet1/5
 bridge-group 1
 nameif inside_4
 security-level 100
interface GigabitEthernet1/6
 bridge-group 1
 nameif inside_5
 security-level 100
interface GigabitEthernet1/7
 bridge-group 1
 nameif inside_6
 security-level 100
interface GigabitEthernet1/8
 bridge-group 1
 nameif inside_7
 security-level 100
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
interface BVI1
 nameif inside
 security-level 100
 ip address 10.0.0.1 255.255.255.0
interface BVI2
 description dmz bridge
 nameif dmz
 security-level 0
 ip address 10.0.1.1 255.255.255.0
ftp mode passive
clock timezone CEST 1
clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00
dns domain-lookup outside
dns server-group DefaultDNS
 name-server 8.8.8.8 outside
 name-server 4.4.4.4 outside
 name-server 192.168.1.1 outside
same-security-traffic permit inter-interface
object network obj_any1
 subnet 0.0.0.0 0.0.0.0
object network obj_any2
object network obj_any3
object network obj_any4
object network obj_any5
object network obj_any6
object network obj_any7
object network dmz_inside
 host 10.0.1.12
 description dmz_host
object network dmz_outside
 host 192.168.1.40
 description dmz_pubblic
access-list outside_access extended permit tcp any4 object dmz_inside eq www
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside_1 1500
mtu inside_2 1500
mtu inside_3 1500
mtu inside_4 1500
mtu inside_5 1500
mtu inside_6 1500
mtu inside_7 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
arp rate-limit 16384
 nat (inside_2,outside) dynamic interface
 nat (inside_3,outside) dynamic interface
 nat (inside_4,outside) dynamic interface
 nat (inside_5,outside) dynamic interface
 nat (inside_6,outside) dynamic interface
 nat (inside_7,outside) dynamic interface
access-group outside_access in interface outside
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 sctp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
timeout conn-holddown 0:00:15
timeout igp stale-route 0:01:10
user-identity default-domain LOCAL
aaa authentication login-history
http server enable
http 10.0.0.0 255.255.255.0 inside_2
http 10.0.0.0 255.255.255.0 inside_3
http 10.0.0.0 255.255.255.0 inside_4
http 10.0.0.0 255.255.255.0 inside_5
http 10.0.0.0 255.255.255.0 inside_6
http 10.0.0.0 255.255.255.0 inside_7
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
 no validation-usage
 crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
  quit
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 10.0.0.5-10.0.0.254 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp authentication-key 1 md5 8 NknyBdRLuPpQXxiGynRLBQGUPRRdJ7jQ
ntp authenticate
ntp trusted-key 1
ntp server 209.165.201.1 key 1 source outside prefer
dynamic-access-policy-record DfltAccessPolicy
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
  no tcp-inspection
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
service call-home
call-home reporting anonymous
call-home
 contact-email-addr [email protected]
 profile CiscoTAC-1
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
password encryption aes
Cryptochecksum:0f1472ec4020272c57ec35d723711472
: end
[OK]
can someone help me?
0 Replies 0
