OID Problem - IR809
Niklas.D
Level 4
Level 4
Hello!
So i am runing a few IR809 Routers
and i started to monitoring the RSSI.
and when i Ask the router 1 with OID .1.3.6.1.4.1.9.9.661.1.3.4.1.1.1.19 i Get back the RSSI
but then on router 2 i get that the OID dont exist instead its now .1.3.6.1.4.1.9.9.661.1.3.4.1.1.1.18 .
should not the OID always be the same ?
balaji.bandi
as per my understand it should be same all over same on the same platform, are you sure the model and version of code same ?
BB
Yes its the same.
Cisco IOS Software, ir800 Software (ir800-UNIVERSALK9-M), Version 15.9(3)M1, RELEASE SOFTWARE (fc1)
Device# PID
*1 IR809G-LTE-GA-K9
