Adding static routes with SNMP
andras.csaszar
Community Member
Dear All,
I have been working for some time now on how to install a static IP route entry into a Cisco router via SNMP.
I had no access. Is it possible that Cisco routers do not support writable routing table via SNMP?
For example, the command
snmpset -v 2c -c xyz myciscoipaddr IP-FORWARD-MIB::ipCidrRouteTable.ipCidrRouteEntry.ipCidrRouteStatus.1.1.1.1.255.255.255.0.0.159.107.196.1 i 4
gives back
Error in packet.
Reason: notWritable (That object does not support modification)
Failed object: IP-FORWARD-MIB::ipCidrRouteStatus.1.1.1.1.255.255.255.0.0.159.107.196.1
Can anyone help in this? (Note that I know how to give a static route via CLI but I need SNMP for a specific purpose...)
David Stanford
I don't believe the routing table has RW access as of yet to add a static route to via snmp.
There is an enhancement request filed for this support - CSCeb69154
You could try using the following as a workaround:
http://www.cisco.com/warp/public/477/SNMP/copy_configs_snmp.shtml
