06-08-2005 08:23 AM
I have 2 bridges with the model AIR-BR1310G-A-K9-R. I need to connect them through INLINE POWER. I have switch 3550 INLINE power. I connected through the switch and no power is coming out.
Any advice or help please..
Thank you
Moe
06-14-2005 08:12 AM
As per your query you cannnot do inline power from a Switch with the 1300 wireless Bridge. These Bridges have their own power injector which must be plugged into the wall. Hope this answers your query
06-30-2005 04:39 PM
The PowerDsine PD-AS-601/18 Active Splitter (18 Volts) can be used with the Cisco Aironet AIR-PWRINJ-BLR2T (12 to 40 VDC) transportation power injector to power the Cisco Aironet 1300 series access point or bridge from a non-Cisco IEEE 802.3af power source, You may need a PD-3001/AC injector as this solution was not tested with a non-802.3af switch such as the 3550 (but will work with a 3650) but it may work.
You can mount the remote access point or bridge up to 200 meters from the switch (100 meters on each side of the power injector). The Cisco Aironet power injector uses dual RG-6 coaxial cable to supply power and Ethernet to the Cisco Aironet 1300 series access point or bridge.
