02-17-2014 09:42 AM
hello
i need to add AIR-CT5760 into PI - can anyone share some usefull docs how to do this?
thanks
02-17-2014 10:26 AM
You should share details on which is the PI version you are using, as 5760 is not supported on al PI's currently.
Infact, only in PI 2.0. On how to add it from PI, you can check the procedure here :
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
02-24-2014 03:27 AM
THe PI is on version 2.0, and CT is on 03.03.01.SE RELEASE
I will try to follow doc you posted.
02-17-2014 01:05 PM
Make sure your 5760 firmware is LOWER than the PI version.
Let your 5760 join PI.
Upgrade the firmware of 5760.
