05-01-2006 10:58 PM
We have recently upgraded our 9500 sw to 2.1.2b and since this, we have been receiving ambiguous snmp traps.
Is there an update i can load into our openview server that will correctly interpret these messages.
Grateful for any help
Jason
05-02-2006 05:14 AM
What is the OID of the trap you are receiving?
05-03-2006 05:25 AM
iso . org . dod . internet . experimental . 94 . 6
hope this helps
05-02-2006 05:48 AM
Once you figure out which MIB the trap is coming from (may need to use the Cisco MIB Navigator: http://www.cisco/com/go/mib), go on to cisco's web site (as described here: http://www.cisco.com/en/US/products/ps5989/products_mib_quick_reference09186a0080216184.html#wp42357
) to download the updated MIB definition.
Install it onto your OpenView NNM server. That should fix up your NNM server's MIB parsing.
Hope this helps, please rate helpful posts.
05-03-2006 05:28 AM
The MIB also seems to be ambiguous. Can't find this anywhere on the searches.
05-03-2006 05:37 AM
I've seen that sometimes the OID actually show in the NMS is not what was sent.
Do you have a packet capture showing the raw trap that you can look at and drill down to see the actual OID?
