ANIDb process may be down
nitsbits_cisco
                   Hi All,
We have recently upgrade LMS 4.0.1 on Windows to LMS version 4.2.3.
After this upgrade, there is one error that has started to occur on Inventory Dashboard in User Tracking Summary --> Unable to connect to Data base, Probable Cause : ANIDbEngine may be down. However, this process is up and running fine.
PDshow output is pasted below.
  Process               State                                     Pid
  UPMDbEngine           Program started - No mgt msgs received    3120
  UPMDbMonitor          Running normally                          3564
  Tomcat                Program started - No mgt msgs received    3652
  TomcatMonitor         Running normally                          3972
  Apache                Program started - No mgt msgs received    2588
  TopoServer            Program started - No mgt msgs received    6588
  RMEDbEngine           Program started - No mgt msgs received    6596
  Proxy                 Program started - No mgt msgs received    6740
  NameServer            Program started - No mgt msgs received    6748
  NameServiceMonitor    Program started - No mgt msgs received    6872
  EDS                   Running normally                          7000
  LicenseServer         Program started - No mgt msgs received    7568
  IpmDbEngine           Program started - No mgt msgs received    7576
  INVDbEngine           Program started - No mgt msgs received    7796
  FHPurgeTask           Running normally                          19984
  FHDbEngine            Program started - No mgt msgs received    7896
  ESS                   Program started - No mgt msgs received    8004
  EssMonitor            Running normally                          8164
  EventFramework        Program started - No mgt msgs received    4572
  PMServer              Running normally                          7344
  SyslogCollector       Running normally                          8100
  EPMDbEngine           Program started - No mgt msgs received    8108
  EPMServer             Running normally                          8340
  FHServer              Running normally                          8516
  diskWatcher           Running normally                          8524
  DFMMultiProcLogger    Program started - No mgt msgs received    8532
  DFMLogServer          Program started - No mgt msgs received    8540
  DFMCTMStartup         Program started - No mgt msgs received    8600
  DfmBroker             Running normally                          8608
  DfmServer             Running normally                          8512
  DfmServer1            Running normally                          9032
  DCRDevicePoll         Transient terminated                      0
  CSSCPServer           Program started - No mgt msgs received    9056
  CSRegistryServer      Running normally                          9128
  CSDiscovery           Never started                             0
  CmfDbEngine           Program started - No mgt msgs received    9120
  CmfDbMonitor          Running normally                          10076
  DCRServer             Running normally                          9820
  CMFOGSServer          Program started - No mgt msgs received    10340
  EssentialsDM          Running normally                          10348
  CAAMServer            Running normally                          10924
  ConfigMgmtServer      Running normally                          10932
  ConfigUtilityService  Running normally                          10940
  ICServer              Administrator has shut down this server   0
  EnergyWise            Running normally                          10572
  PMCOGSServer          Program started - No mgt msgs received    7272
  IPMOGSServer          Program started - No mgt msgs received    6988
  TISServer             Program started - No mgt msgs received    10596
  DFMOGSServer          Program started - No mgt msgs received    11824
  InventoryCollector    Running normally                          12244
  Interactor            Program started - No mgt msgs received    12080
  InventoryCollector1   Program started - No mgt msgs received    12088
  Interactor1           Program started - No mgt msgs received    12828
  NOSServer             Running normally                          12836
  PTMServer             Running normally                          12848
  UPMProcess            Running normally                          12856
  EDS-GCF               Running normally                          12864
  jrm                   Running normally                          12888
  CTMJrmServer          Running normally                          14540
  ChangeAudit           Program started - No mgt msgs received    15212
  SyslogAnalyzer        Running normally                          15220
  DataPurge             Administrator has shut down this server   0
  IPMProcess            Program started - No mgt msgs received    15236
  ANIDbEngine           Program started - No mgt msgs received    15244
  ANIServer             Running with busy flag set                15708
  UTMajorAcquisition    Program started - No mgt msgs received    21356
  MACUHIC               Running normally                          15992
  UTLITE                Running normally                          16000
  UTManager             Running normally                          16008
  VNMServer             Program started - No mgt msgs received    16016
  WlseUHIC              Running normally                          16024
  AdapterServer1        Program started - No mgt msgs received    16036
  AdapterServer         Program started - No mgt msgs received    16044
AFROJ AHMAD
Hi Nitin,
Try restarting the server ,if that did not help then you can reintialize the ANI database.
ANI database does not contain any historical data so reint the ANI database will not loose
anything.
procedure:
stop the daemon manager
command to REINIT:
/opt/CSCOpx/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI (solaris\linux)
NMSROOT\bin\perl.exe NMSROOT\bin\dbRestoreOrig.pl dsn=ani dmprefix=ANI  (windows)
start the daemon manager.
Thanks-
Afroz
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
