ANIServer is still initializing during more than 20 mn
slevy-ares
I have installed LMS 2.6 on Windows Server 2003 Standard Edition.
Pentium 4 CPU 3.40GHz; RAM: 3,12 GB.
After a reboot or after start the process of LMS, I must wait more than 20-30mn (after, all is ok) for use Campus Manager. Why is it so long?
Joe Clarke
With the whole LMS bundle on a server, there are a lot of CPU-intensive processes that get kicked off.
Things that help load time are more CPUs and more memory. You didn't mention how many real CPU cores this machine has or how many devices you are managing, but 20-30 minutes before all the LMS daemons are up is generally the norm.
The problem is solved. There was a problem with ani.db. I used the command "reinitdb.pl -restore" and now I just wait 5-10 minutes.
