Ansible Restore Playbook Issue
yuganwimukthi
I create a playbook to restore my router backup using ansible, but it didn't work properly. I attached a screenshot of my error.
- hosts: CR01
connection: network_cli
gather_facts: false
tasks:
- name: push config file
ios_config:
src: "home/yugan/desktop/backup/config/CR1.cfg"
- name: save running to startup
ios_config:
save_when: modified
5 Replies 5
can you cat the entire file ? I do not count to line 19...
YAML syntax errors are often related to indentation or missing double quotes...
yuganwimukthi
--> src: "home/yugan/desktop/backup/config/CR1.cfg" <--
The ending double quote does not appear in your screenshot. Make sure it is actually there
Removed double quote on "src" section after that it working properly. Thank you for your help.
issamhailoua
can you please show me your CR1.cfg file ?
