Ansible variables not recognized
Gioacchino
Hi, I'm going through this tutorial to learn ansible with Cisco 9k3
https://developer.cisco.com/learning/modules/intro-ansible-iosxe/ansible-ios-modules/gather-information/
All has been good till the moment I tried to run this playbook (ansible-playbook -v -i hosts 02-ios_facts.yaml)
- name: Sample IOS playbook to retrieve facts
  hosts: iosxe
  gather_facts: no
  tasks:
  - name: retrieve ios facts
    cisco.ios.ios_facts:
  - name: display version and serial number
    debug:
      msg: "The IOS version is: {{ ansible_net_version }} and the SN is: {{ ansible_net_serialnum }}"
  - name: print out interface information
    debug:
      var: ansible_net_interfaces
Besides the warning
[WARNING]: ansible-pylibssh not installed, falling back to paramiko
eventualy I get
"ansible_net_interfaces": "VARIABLE IS NOT DEFINED!: 'ansible_net_interfaces' is undefined. 'ansible_net_interfaces' is undefined"
I had a look at this page
https://docs.ansible.com/ansible/latest/collections/cisco/ios/ios_user_module.html#ansible-collections-cisco-ios-ios-user-module
and I replaced the variable (ansible_net_interfaces) with others. Some are recognized (ansible_net_hostname), other are not (ansible_net_config).
Who's wrong? Me, Ansible or the IOS-XE version (17.09.03)?
If it is me, where am I wrong?
Gio
6 Replies 6
Gioacchino
Really no one has encountered this issue earlier?
Gio
Gioacchino
Who should define this variable or where this variable should have been already defined?
Ben Hobday
Hi Gio, did you figure this out? I'm now stuck on the same thing and new to it all.
@Ben Hobday,
It's been a whilke that I haven't used it. I don't remember whether I have or I haven't found a solution
I have to resume work on this for sure in the future, at that moment I will update this thread.
Sorry,
Gio
asherpat1
Hi Gio,
I think its because the default 'gather subset' value in the cisco.ios.ios_facts module is set to min, meaning unless declared it will not gather many of those pre-defined variables
You need change the gather_subset parameter in the yaml file to either 'all' or to be more specific in your case 'interfaces'
Try this instead - it worked for me (my indentation might be bad sorry- i struggled to paste my yaml file and keep indentation but I ran this in my lab and it works)
hosts: iosxe
gather_facts: no
tasks:
gather_subset:
- interfaces
debug:
debug:
https://docs.ansible.com/ansible/latest/collections/cisco/ios/ios_facts_module.html#ansible-collections-cisco-ios-ios-facts-module - have a look at the 'gather_subset' parameter
Asher
rob-lobster
Asher's solution is correct, it needs the gather_subset parameter. The playbook also needs the
connection: network_cli parameter set higher if you're running from the requirements.txt, or it's not set as an environment variable.
Thank you for saving me trouble with the lab! Frustrating to troubleshoot broken labs.
