Any command get port info
HoangNguyen7687
Which command that I use to get switch port info such as IP, where it connected from. Thank you.
pieterh
I'm not sure I understand your question correctly
a switchport operates at  Layer-2 (not Layer-3) and as such  a switchport has "no knowledge" about IP-addresses.
you can use "show mac address-table interface <interfacename>" to see MAC adresses
you can use "show ip interfaces brief" to show adresses configured on this switch
you can use "show users" to see information about users that are connected to the management address of this switch.
