Decododing Wireshark data
angel-moon
Level 3
Level 3
Not exactly a Cisco topic but does anyone have any recommendations for software that "decodes" Wireshark Captures?.  Looking for a bit of help in that area.
Thanks in advance!
Replies rated!
Deepak Kumar
There is no direct software, Id packets are encrypted then you must need certificate & private key for decrypt the data here is the tutorial:
https://support.citrix.com/article/CTX116557
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Martin L
INE (and others) has released Wireshark video course which is pretty good one.
