Apache errors after cwcs3_0_4 update
dksteinhauser
Community Member
Can anyone help?
After installing the cwcs3_0_4_win.exe patch, I cannot connect to Ciscoworks. It shows a "Page connot be displayed" error. When I try to start the "Apache" server service, there are 3 errors generated in the event log.
Event Type: Error
Event Source: Apache Service
Event Category: None
Event ID: 3299
Date: 9/11/2006
Time: 3:36:47 PM
User: N/A
Computer: CMEARCWKS01
Description:
The Apache service named C:\PROGRA~1\CSCOpx\MDC\Apache\Apache.exe reported the following error:
>>> [Mon Sep 11 15:36:47 2006] [warn] pid file c:/program files/cscopx/mdc/apache/logs/httpd.pid overwritten -- Unclean shutdown of previous Apache run? <<<
before the error.log file could be opened.
More information may be available in the error.log file. .
Event Type: Error
Event ID: 3299
Date: 9/11/2006
Time: 3:36:47 PM
User: N/A
Description:
>>> [Mon Sep 11 15:36:47 2006] [error] Apache.exe caused a EXCEPTION_ACCESS_VIOLATION in module ntdll.dll at 001B:77F8F281, RtlpWaitForCriticalSection()+138 byte(s) <<<
Event Type: Error
Event ID: 3299
Date: 9/11/2006
Time: 3:36:47 PM
User: N/A
Description:
Apache.exe child process caused an exception and reported error
Apache.exe child process will be restarted ! .
Any thooughts? I've tried un-installing the patch, and reverting to 3.0.3, but still the same problem. I've restarted the system several times, and tried a reinstall of both 3.0.3 and 3.0.4.
Joe Clarke
This error is caused by a DLL conflict. Specifically, there are multiple versions of the OpenSSL DLLs needed by Apache in the system executable PATH. To resolve this problem, check your PATH environment variable. Make sure all of the CiscoWorks paths are FIRST. Alternatively, make sure there are only one of each of libeay32.dll and ssleay32.dll on the system, and that they are the ones under NMSROOT\bin.
Note: when the DLL problem is resolved, you should be able to run:
openssl version
From the command line, and not get any errors. The output should be:
OpenSSL 0.9.7i 14 Oct 2005
Bingo!!
That's was the problem. An Upgrade to Legato plus the upgrade to Ciscoworks added 2 new *eay32.dll files.
Thanks for the help!
