APIC-EM
Dan Smith
Community Member
I'm wondering about the minimum requirement for this server, can we change the drive options to SSD
Server Option
Image Format
Bare metal/ISO
Hardware Specifications
CPU (cores)
6
Memory
64GB
Note
For a multi-host hardware deployment (2 or 3 hosts) only 32GB of RAM is required for each host.
Disk Capacity
500GB of available/usable storage after hardware RAID
RAID Level
Hardware-based RAID at RAID Level 10
CPU Speed
2.4 GHz
Disk I/O Speed
200 MBps
Network Adapter
Note
A single network adapter or network interface controller (NIC) is the minimum requirement. For security, we recommend that you use and configure two NICs on the server. See Security in the Limitations and Restrictions section of the release notes for additional information.
Networking
Web Access
Required
Browser
The following browsers are supported when viewing and working with the Cisco APIC-EM:
  • Google Chrome, version 46 or later
Could we use the following.
SSD drives in Raid5 or Raid1 rather than Raid10? These will provide much better performance than traditional disks and should be approximately the same cost as it would be to get the slower disks with Raid10.
As long as the disk I/O is 200 Mbps i don't think it matters what type of disks you use or RAID type.  RAID 10 is listed because you get performance and redundancy.  The performance is the most important piece.  If you can get 200 Mbps with SSD in RAID 5 go for it.  When you install it will test the disk configuration and tell you what the performance is.
