Archive command to save config to flash
Mmiselo
Good day,
I have a Cisco router 1921 that doesn't save the config file to the flash like other routers. May you please help with resolving the issue or help with other ways to achieve this.
This is what I configured on all of the routers,
archive
path flash:mybackup
maximum 1
write-memory
Nelson
6 Replies 6
balaji.bandi
what is the version of the IOS code running on this router ?
can you post below output :
#show version
#show archive
#dir
BB
Hello BB,
See the attached file.
Nelson
if you using USB flash,  that need to change in config also right :
dir flash:   - do you see any output, if not change as below  and test it
archive
path usbflash0:mybackup
maximum 1
write-memory
BB
Hello BB,
Still no luck after changing and write to memory,
maximum 1
write-memory
#sh archive
The maximum archive configurations allowed is 1.
There are currently no configuration saved.
The next archive file will be named usbflash0:mybackup-<timestamp>-0
Archive # Name
try again config t
add some config which not effect and write and post below information again
dir
dir flash:
BB
just found out to be a bug on only the 1921 Router ( your version does not show as a fixed version).
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtr74737
Try offloading to FTP or  TFTP or any other destination to see if that works.
BB
