Archive On Changes - Ciscoworks
svanhandel
Looking to automatically save a configuration in the CW RME archive on any configuration change to routers/switches.  Is there a fast and easy way to do this? Yes.. Yes... I know that archives can be scheduled periodically.  I am looking to trigger it on the router/switch.  EEM?  Parsing syslog?
Appreciate the feedback!
Thanks!
Sean.
Thomas Masters
Level 5
Level 5
Within RME syslogs there should already exist an Automated Action you can enable which will trigger a synch archive anytime a configuration change is made on the device.  You must setup logging on the device to send the logs to RME then any CONFIG_I type message will be the trigger.
RME -> Tools -> Syslog -> Automated Actions
RME Syslogs
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.3/user/guide/syslog.html
Good luck.
Tom
