ASA 5505 licensed limit for SSH sesions
cindia_espinal
I have the default license for a ASA 5505 and this last Friday I received the attached log for SSH sessions through this firewall; we want to be clear about this issue. This limitation has to be with the 10 Inside Host or the Total VPN Peers limitations in this license? This firewall exists only to agree with a PCI requirement between our router and a communication with a Payment Card Industry Brand, all of this in the same site.
ASA5505 <164>Sep 09 2011 10:42:08: %ASA-4-450001: Deny traffic for protocol 6 src DMZ:X.X.X.X/2479 dst DMZ1:X.X.X.X/22, licensed host limit of 10 exceeded.
I hope that the communications through 22 TCP port, are not countable for license propose.
Licensed features for this platform:
Maximum Physical Interfaces  : 8
VLANs                        : 3, DMZ Restricted
Inside Hosts                 : 10
Failover                     : Disabled
VPN-DES                      : Enabled
VPN-3DES-AES                 : Enabled
SSL VPN Peers                : 2
Total VPN Peers              : 10
Dual ISPs                    : Disabled
VLAN Trunk Ports             : 0
Shared License               : Disabled
AnyConnect for Mobile        : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials        : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions      : 2
Total UC Proxy Sessions      : 2
Botnet Traffic Filter        : Disabled
We will appreciate any comments!
Rgds!
Richard Burts
Cindia
You are correct that this error is related to the license restriction for inside hosts.
While SSH does encrypt the data it sends, and that sounds perhaps a bit like VPN, SSH does not count as VPN in terms of the licensing on the ASA.
Rick
Rick
