ASA losing Config after reboot.
adrian.farrugia
Our ASA 5515 is loosing the config after a reboot.
First of all I copied the running config to the startup config.
What I am noticing is that when I do show version, the configuration register is as follows: Configuration register is 0x1
Is this the problem and shall I change the configuration register to: 0X2102
Thanks & Regards,
Adrian
6 Replies 6
Mark Malone
No 0x1 should be good , whats the bootvar show ---show bootvar
The default configuration register value is 0x1. For more information about the configuration register, see the Cisco ASA 5500 Series Command Reference.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/admin_trouble.html
Thanks for your reply.
The bootvar is showing the following:
BOOT variable = disk0:/asa861-smp-k8.bin;disk0:/asa914-smp-k8.bin
Current BOOT variable = disk0:/asa861-smp-k8.bin;disk0:/asa914-smp-k8.bin
CONFIG_FILE variable =
Current CONFIG_FILE variable =
So your image is there but looks like bootvar is missing config file to load up but your saving to startup so it should show up  , take look at this link you can manually set it in config and shows few quick steps , try wr in case just as another option to copy run start
https://learningnetwork.cisco.com/thread/61349
Thanks for your reply. I will have a look.
Is it normal that a Cisco 3750 switch do not have the command show bootvar?
3750 should have show boot
