Showing results forĀ
Search instead forĀ
Did you mean:Ā
ASA5510 - ASA5525-x
cwasilak
Good Afternoon, I need some help, I am migrating my config from an asa5510 to asa5525-x I started to try moving all of the settings over but then it got a little confusing. Is there some one that can help me
liviu.gheorghe
Hello @cwasilak .
can you post the config from ASA5510 and also the config from the ASA5525 - the initial config will do or you can share what you have so far.
Regards, LG
*** Please Rate All Helpful Responses ***
Thank you LG, I just gave you the initial 5525
most of the commands can be taken over as is. Where do you get stuck ?
Attached the configuration file for the ASA5525.
There are some issues with the new config - for example 3DES is not supported in the ASA version 9.2 and for that reason some of the ISAKMP policies, the ones configured with 3DES encryption, are not configurable anymore.
Try it out and let is know the results.
Regards, LG
