Asad Rizvi
asadrizvi1
I want to configure the Syslog on Cisco Router and Cisco switches what are the correct steps to configure the Syslog server.
yjdabear
See the "Enabling Syslog" section on how to enable the syslog client in IOS.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/intsolns/as5xipmo/sysmgt.htm#xtocid4
CatOS switches will require a different set of commands obviously.
A syslog server is usually an entity external to the router/switch. Its configuration is dependent on what product/implementation is actually chosen.
