06-30-2020 02:12 PM
When I tried to upgrade from asr1002x-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin to asr1000-universalk9.16.09.05.SPA.bin version, I used "boot system bootflash:" command, but when the device reboot it didn't do it. These are the output when the device is power on:
Initializing Hardware ...
System integrity status: 90170400 12030117
U
System Bootstrap, Version 16.2(2r), RELEASE SOFTWARE
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: PowerOn
Initializing PAMs
ASR1002-HX platform with 33554432 Kbytes of main memory
Warning: filesystem is not clean
File size is 0x1bf52580
Located asr1002x-universalk9.03.16.06.S.155-3.S6-ext.SPA.bin
Image size 469050752 inode num 24, bks cnt 114515 blk size 8*512
Boot image size = 469050752 (0x1bf52580) bytes
ROM:RSA Self Test Passed
ROM:Sha512 Self Test Passed
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
calculated fb3409d3:3e904c8e:ac9a7695:6652c5d5:6d13f9d7
expected fb3409d3:3e904c8e:ac9a7695:6652c5d5:6d13f9d7
Validating main package signatures
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash 1 contained errors which were auto-corrected.
%IOSXEBOOT-4-SWTREE: (rp/0): ERROR: Route processor type (2kp) not valid for this route processor (RP-2KH) Failure processing package asr1002x-rpbase.03.16.06.S.155-3.S6-ext.SPA.pkg
%IOSXEBOOT-4-ABORT: (rp/0): ERROR: Route processor type (2kp) not valid for this route processor (RP-2KH) Failure processing package asr1002x-rpbase.03.16.06.S.155-3.S6-ext.SPA.pkg Failed to process provisioning file (/tmp/packages.conf).
Starting IOS XE kernel dump from previous failure.
Expected completion time is less than 5 minutes.
System will automatically reboot within 20 minutes.
Kdump failed to finish the core dump, please check if out of space
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sdb1 29584352 29584352 0 100% /misc/scratch
-rw-r--r-- 1 0 0 1006538752 Jun 30 10:23 /misc/scratch/core/kernel.rp_RP-2KH_0.core.TEMP_IN_PROGRESS
Deleting the incomplete core file
Rebooting now...
U
Last reset cause: CPU-ResetRequest
AND THE PROCCESS STARTS AGAIN AND AGAIN AND SO ON....
I can't stop this, or enter in the ROMmom mode.
Do you have any idea about how to solve this issue?
Thanks for your support
06-30-2020 11:40 PM
- Check if this thread can help you :
https://community.cisco.com/t5/routing/asr1002-does-not-boot-new-image/td-p/2617964
M,
07-01-2020 04:37 PM
@marce1000 is correct.
1. The IOS file are wrong. The HX is being forced to load an IOS meant for a "plain" ASR 1000.
