ASR1002 does not boot new image
mmoulson1
Level 4
Level 4
Hi all,
I’m trying to upgrade an ASR1002 from:
asr1002x-universalk9.03.13.00.S.154-3.S-ext.SPA.bin
to:
asr1002x-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin
I copied the new file to my bootflash and used the:
“boot system bootflash:asr1002x-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin” command saved my config and reloaded.
However when it boots I get:
%IOSXEBOOT-4-SWTREE: (rp/0): ERROR: Route processor type (1ng) not valid for this route processor (RP-2KP) Failure processing package asr1001x-rpbase.03.13.02.S.154-3.S2-ext.SPA.pkg
%IOSXEBOOT-4-ABORT: (rp/0): ERROR: Route processor type (1ng) not valid for this route processor (RP-2KP) Failure processing package asr1001x-rpbase.03.13.02.S.154-3.S2-ext.SPA.pkg Failed to process provisioning file (/tmp/packages.conf).
Starting IOS XE kernel dump from previous failure.
  Expected completion time is less than 5 minutes.
  System will automatically reboot within 20 minutes.
And the system then boot loops after a few mins. I can get access to rommon and I still have the original image on the flash but I can’t find a way to tell the unit to boot the old image from rommon?
Also how do I get round the above errors to run my new image?
Thanks in advance
Matty
This is your original IOS file, right?  Look at the highlighted item in RED.
Now compare this.
11 Replies 11
mmoulson1
Level 4
Level 4
OK so to answer my own question:
rommon 1 > BOOT=bootflash:asr1002x-universalk9.03.13.00.S.154-3.S-ext.SPA.bin
rommon 2 > sync
rommon 3 > reset
If anyone has the correct procedure to upgrade please share! Obviously just changing the
boot system
command is not correct!
I see that
asr1(config)#boot system ?
  WORD   TFTP filename or URL
  flash  Boot from flash memory
I'm using for example
boot system flash bootflash:asr1000rp1-advipservicesk9.03.10.03.S.153-3.S3-ext.bin
I'm not sure
bootflash:<image.bin>
qualifies as URL - try adding the
flash keyword to your boot system
command and see what happens...
use boot system flash bootflash:<image.bin>
Remember to take out any old boot statements and save the config.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Thanks for the replies, I don't think it's the boot statement that is the issues as I can see it is loading my new image:
Located asr1001x-universalk9.03.13.02.S.154-3.S2-ext.SPA.bin
Image size 489740544 inode num 14, bks cnt 119566 blk size 8*512
The problem is after it loads the images I get these errors then it just boot loops after a few mins:
Matty
Now compare this.
Nice find Leo... it seems like the loaded image that its trying to use for boot is:
Matty, can you show us the output of
show flash
or it might be
show bootflash
Doh! Thanks guys! I'm going to blame my tiredness for not spotting that, I was trying to get things don’t before a 4hr drive home!
Nothing to do with my colleague downloading the wrong image for me!
Thanks for the ratings, Matty.   :)
By the way, we all make mistakes.  We just have to learn how to laugh at ourselves.  :)
hi Bilal I have one question
I installed the asr 1001x router image in asr 1002x router but its not coming to enable mode.
Hi Experts,
I tried to boot SD.WAN image on ASR1002X it was going to rommon mode and i tried to boot with IOS XE it was also showing  error, please help me to solve this issue.
flash Logs:
rommon 1 > dir usb1:
File System: FAT16
2 0 drw- .Spotlight-V100
78 0 drw- .fseventsd
4 0 drw- System Volume Information
72 0 drw- .Trashes
14 774908831 -rw- asr1002x-ucmk9.16.12.4.SPA.bin
22 767979426 -rw- asr1002x-universalk9.16.12.01a.SPA.bin
Booting with SD-WAN Image logs
rommon 2 > boot usb1:asr1002x-ucmk9.16.12.4.SPA.bin
Located asr1002x-ucmk9.16.12.4.SPA.bin, start cluster is 14
Image loaded
Boot image size = 774908831 (0x2e302b9f) bytes
ROM:RSA Self Test Passed
ROM:Sha512 Self Test Passed
Package header rev 1 structure detected
Calculating SHA-1 hash...done
validate_package_cs: SHA-1 hash:
calculated d6f51674:87ec30e8:2c74a498:f7895ae2:2321670d
expected d6f51674:87ec30e8:2c74a498:f7895ae2:2321670d
Validating main package signatures
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
%IOSXEBOOT-4-PART_INVALID: (rp/local): /dev/bootflash has an invalid partition table that must be repaired.
%IOSXEBOOT-4-PART_REPAIR: (rp/local): The system will repair /dev/bootflash now.
%IOSXEBOOT-4-PART_REPAIR: (rp/local): This may cause loss of data and configuration on /dev/bootflash.
%IOSXEBOOT-4-PART_REPAIR_FINISHED: (rp/local): Partitioning complete.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/local): partition /dev/bootflash1 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): The system will repair /dev/bootflash1 now.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): This will cause a complete loss of data.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/local): partition /dev/bootflash5 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): The system will repair /dev/bootflash5 now.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/local): partition /dev/bootflash6 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): The system will repair /dev/bootflash6 now.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/local): partition /dev/bootflash7 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): The system will repair /dev/bootflash7 now.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/local): partition /dev/bootflash8 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): The system will repair /dev/bootflash8 now.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/local): partition /dev/bootflash9 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): The system will repair /dev/bootflash9 now.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/local): partition /dev/bootflash10 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): The system will repair /dev/bootflash10 now.
%IOSXEBOOT-4-FILESYS_INVALID: (rp/local): partition /dev/bootflash11 has an invalid filesystem that must be re-initialized.
%IOSXEBOOT-4-FILESYS_REPAIR: (rp/local): The system will repair /dev/bootflash11 now.
● localhost
State: initializing
Jobs: 6 queued
Failed: 0 units
Since: Sun 2020-12-06 23:38:43 Universal; 1min 28s ago
CGroup: /
├─init.scope
│ └─1 /init
└─system.slice
├─systemd-journald.service
│ └─199 /lib/systemd/systemd-journald
├─systemd-udevd.service
│ └─251 /lib/systemd/systemd-udevd
├─report_fails.service
│ └─429 systemctl status -l -n 100 -o short-monotonic --no-pager
├─audit.service
│ ├─438 /sbin/auditd -n
│ └─448 /sbin/audispd
└─system-systemd\x2dfsck.slice
└─systemd-fsck@dev-usb1.service
├─427 /bin/bash /sbin/fsck_or_mkfs.sh /dev/usb1
└─440 /sbin/fsck -y -T /dev/usb1
>>> Rebooting
Failed to connect to bus: No such file or directory
Failed to connect to bus: No such file or▒
Initializing Hardware ...
System integrity status: 00000610
System Bootstrap, Version 16.2(1r), RELEASE SOFTWARE (fc1)
Copyright (c) 1994-2016 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
SPI Flash 4KB Descriptor Area Checksum = 0x6f5a0db2
ASR1002-X platform with 4194304 Kbytes of main memory
IOSXE Logs
rommon 3 > boot usb1:asr1002x-universalk9.16.12.01a.SPA.bin
Located asr1002x-universalk9.16.12.01a.SPA.bin, start cluster is 22
Image loaded
Boot image size = 767979426 (0x2dc66fa2) bytes
calculated b5b50b40:a682c41e:99331b10:f0fe5c38:2524ef27
expected b5b50b40:a682c41e:99331b10:f0fe5c38:2524ef27
Image validated
● localhost
State: initializing
Jobs: 6 queued
Failed: 0 units
Since: Sun 2020-12-06 23:29:24 Universal; 1min 29s ago
CGroup: /
├─init.scope
│ └─1 /init
└─system.slice
│ └─187 /lib/systemd/systemd-journald
│ └─248 /lib/systemd/systemd-udevd
│ └─428 systemctl status -l -n 100 -o short-monotonic --no-pager
├─audit.service
│ └─441 /sbin/audispd
├─426 /bin/bash /sbin/fsck_or_mkfs.sh /dev/usb1
└─437 /sbin/fsck -y -T /dev/usb1
Yes, Its working....
