ASR 1002 NOT BOOTING COMPLETELY
oyenibi4lv
Dear Team,
Please my ASR1002 is not loading completely. when accessed via console, the below error message is displaced  and i cannot enter rommon mode  neither can i do any other thing else from console
System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc
will appreciate any assistance on this.
9 Replies 9
Mark Elsen
                              - I can not see any error being displayed (yet....)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
@Mark Elsen . thanks for your response.
The router got stuck  during boot process and showing below message  via console.  basically, it got stuck showing the below message
i mean the router got stuck showing this message; System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport Copyright (c) 2009 by cisco Systems, Inc.
I am logging through console but it won't let me allow to get a prompt. i have reboot it 2 times but it stops responding at System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
 - This looks like  a basic and or possibly a hardware problem. Have a cold power cycle of the device. Keep the console connected. Look for error messages during power up, if any.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
@Mark Elsen  no Error message when power cycle, the device will load and stopped at same message;
 - Seems like factory defaults reset remains an only possible left over option , a procedure can be found in the link below. However if that does not work neither , the device is corrupt and probably needs to be replaced (RMA). Discuss the situation further with Cisco TAC.
        https://www.hardreset99.com/routers/cisco/cisco-asr-1002x-router-how-to-reset-to-factory-defaults-settings/
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Mark Elsen
                       (forgot to mention) -> Also check if there any led status indicators , pointing to severe problems.
 M.
       Beauty and terror
      Just keep going
       No feeling is final
the critical led light is on
                   - Seems quite indicative of a serious problem -> RMA
 M.
       Beauty and terror
      Just keep going
       No feeling is final
