09-06-2023 08:26 AM
Dear Cisco Community,
I have to upgrade two Cisco ASR 1002-X Routers.
Current version is: :asr1002x-universalk9.17.03.05.SPA.bin
Version to upgrade to: asr1002x-universalk9.17.06.05.SPA.bin
Current Rommon version is 17.3(1r)
Can I upgrade direct from above current version to suggested upgrade version i.e. from 17.3.5 to 17.6.5.
Or is there any upgrade path for this.
3. If there's any upgrade path, please do share the upgrade path for my current version to suggested version i.e. from 17.3.5 to 17.6.5 (and also the rommon software package).
Please share the upgrade steps as I could not find it the documents
should I use the command boot system flash ?
Solved! Go to Solution.
09-06-2023 09:01 AM
Perfect.
09-06-2023 08:32 AM - edited 09-06-2023 08:32 AM
Hello @AbdElRahman.Ashraf,
Check the minimum recommended Rommon version for you targeted Firmware:
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/rommon/asr1000-rommon-upg-guide.html.
With 17.3.1 it seems OK.
09-06-2023 08:54 AM
Hello dear,
what about the upgrade of the ios steps
#no boot system flash bootflash:asr1002x-universalk9.16.09.05.SPA.bin
#boot system flash bootflash:asr1002x-universalk9.17.05.06.SPA.bin
regards
09-06-2023 09:01 AM
09-06-2023 04:08 PM
