ASR 1002-X upgarde steps
Dear Cisco Community,
I have to upgrade two Cisco ASR 1002-X Routers.
Current version is: :asr1002x-universalk9.17.03.05.SPA.bin
Version to upgrade to: asr1002x-universalk9.17.06.05.SPA.bin
Current Rommon version is     17.3(1r)
Can I upgrade direct from above current version to suggested upgrade version i.e. from 17.3.5 to 17.6.5.
Or is there any upgrade path for this.
3. If there's any upgrade path, please do share the upgrade path for my current version to suggested version i.e. from 17.3.5 to 17.6.5 (and also the rommon software package).
 Please share the upgrade steps as I could not find it the documents
should I use the command boot system flash ?
@AbdElRahman.Ashraf,
Perfect.
Best regards
M02@rt37
Hello @AbdElRahman.Ashraf,
Check the minimum recommended Rommon version for you targeted Firmware:
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/rommon/asr1000-rommon-upg-guide.html.
With 17.3.1 it seems OK.
Best regards
Hello dear,
what about the upgrade of the ios steps
#no boot system flash bootflash:asr1002x-universalk9.16.09.05.SPA.bin
#boot system flash bootflash:asr1002x-universalk9.17.05.06.SPA.bin
regards
Perfect.
Best regards
