ASR 9006 Failed to convert nodeid to pq nodeid ''Subsystem(1597)'
aguntukkk
lrd[332]: Failed to convert nodeid to pq nodeid ''Subsystem(1597)' detected the 'fatal' condition 'Code(4)': Invalid argument'
Why i am getting this error ? Need help
10 Replies 10
balaji.bandi
what is the full Log message, what version of code running the device ?
is this you getting continue in the logs or when you doing any config - looks for me Bug.
BB
Dear Sir.
*what is the full Log message, what version of code running the device ?*
*is this you getting continue in the logs or when you doing any config -
looks for me Bug.*
i am getting continue in the logs. But not getting anything when i am
doing any configuration.
I did a quite extensive search but could not find anything on that particular message.
I know it is bad practice to block something from being seen that you don't understand, but you could configure the logging discriminator below to at least prevent that message from filling up your logs:
logging discriminator DROP_PQ msg-body drops Failed to convert nodeid to pq nodeid
logging buffered discriminator DROP_PQ
logging console discriminator DROP_PQ
I want to see all logs only do not see DROP_PQ
i have given command
match1 DROP_PQ
match1 DROP_PQ
But now can not see any logg
Please help me with right command
Need help
post the output of:
show log
RP/0/RSP0/CPU0:SG-CDN-GW#sh log
Sat May 21 11:27:52.555 BDT
Syslog logging: enabled (0 messages dropped, 0 flushes, 0 overruns)
Console logging: level informational, 11924 messages logged
Monitor logging: level debugging, 0 messages logged
Trap logging: level notice, 0 messages logged
Buffer logging: level debugging, 24748 messages logged
Log Buffer (2097152 bytes):
RP/0/RSP0/CPU0:May 21 07:55:11.423 BDT: lrd[332]: Failed to convert nodeid
Invalid argument'
RP/0/RSP0/CPU0:May 21 07:55:21.427 BDT: lrd[332]: Failed to convert nodeid
Invalid argument'
Invalid argument'
RP/0/RSP0/CPU0:May 21 07:55:31.432 BDT: lrd[332]: Failed to convert nodeid
Invalid argument'
Invalid argument'
RP/0/RSP0/CPU0:May 21 07:55:41.436 BDT: lrd[332]: Failed to convert nodeid
Invalid argument'
Invalid argument'
RP/0/RSP0/CPU0:May 21 07:55:51.441 BDT: lrd[332]: Failed to convert nodeid
Invalid argument'
Invalid argument'
RP/0/RSP0/CPU0:May 21 07:56:01.445 BDT: lrd[332]: Failed to convert nodeid
Invalid argument'
Invalid argument'
RP/0/RSP0/CPU0:May 21 07:56:11.450 BDT: lrd[332]: Failed to convert nodeid
Invalid argument'
Invalid argument'
RP/0/RSP0/CPU0:May 21 07:56:21.454 BDT: lrd[332]: Failed to convert nodeid
 - Use advisory software version ,  if applicable : https://software.cisco.com/download/home/282423206/type/280805694/release/7.3.2 . check if  that can help.
 M.
Can i drop this message only from the log. If yes. then please send a right
command to drop it
Dear Sir ,
i am getting log message from asr 9006 mention bellow Screen Shot 2022-05-25 at 1.22.49 PM.png
RP/0/RSP0/CPU0:SG-CDN-GW#sh logg
Wed May 25 13:11:41.390 BDT
Console logging: level informational, 12821 messages logged
Buffer logging: level debugging, 1805 messages logged
RP/0/RSP0/CPU0:May 25 10:45:10.495 BDT: lrd[332]: Failed to convert nodeid to pq nodeid ''Subsystem(1597)' detected the 'fatal' condition 'Code(4)': Invalid argument'
RP/0/RSP0/CPU0:May 25 10:45:14.752 BDT: SSHD_[65798]: %SECURITY-SSHD-6-INFO_USER_LOGOUT : User 'rajesh' from '180.148.211.70' logged out on 'vty0'
RP/0/RSP0/CPU0:May 25 10:45:20.500 BDT: lrd[332]: Failed to convert nodeid to pq nodeid ''Subsystem(1597)' detected the 'fatal' condition 'Code(4)': Invalid argument'
RP/0/RSP0/CPU0:May 25 10:45:30.504 BDT: lrd[332]: Failed to convert nodeid to pq nodeid ''Subsystem(1597)' detected the 'fatal' condition 'Code(4)': Invalid argument'
RP/0/RSP0/CPU0:May 25 10:45:40.509 BDT: lrd[332]: Failed to convert nodeid to pq nodeid ''Subsystem(1597)' detected the 'fatal' condition 'Code(4)': Invalid argument'
Can i drop this only this message  from the log. If yes. then please help me with right command to drop it
