ASR-901 not compatible with AAA PAssword Policy?
KGrev
Level 4
Level 4
I'm trying to configure a AAA common-criteria policy much like our other cisco devices but on our ASR-901 it doesn't appear that I can use the same commands? Has anyone had this issue on other devices? Is there an alternate way to do this?
Cisco A901-6CZ-F-D    Ver: 156-2.SP9
Thanks for any help.
Richard Burts
Perhaps you can provide some specifics of commands that you are trying that are not working?
Rick
@Richard Burtssorry it has taken me this long to respond.
The command I have on other models of routers is "aaa common-criteria policy WORD"
But on this particular model I can type "aaa" but dont get the same options.
Here are the next options:
accounting
attribute
authentication
cache
configuration
dnis
group
local
login
max-sessions
memory
nas
new-model
password
pod
policy
route
server
service-profile
session-id
traceback
user
Not a problem about timing. I am not familiar with this product. In looking at documentation I see some vague references about using aaa with Radius or Tacacs but very little detail about the details of configuration. Given the options that you see available I am guessing that common-criteria is not supported on this product. Wish I could be more help.
Rick
