02-01-2021 12:08 AM
I have a Cisco ASR 9010 running IOS XR 6.4.2.
Since two weeks ago it has generated the following alarms every day:
Jan 31 19:19:15.158 GMT+2: 42380: RP/0/RSP0/CPU0:Jan 31 19:19:15.158 GMT+2: pfm_node_rp[138]: %PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Set|online_diag_rsp[9270]|System Punt/Fabric/data Path Test(0x2000004)|failure threshold is 3, (slot, NP) failed: (0/1/CPU0, 0)
Jan 31 19:31:26.694 GMT+2: 42381: RP/0/RSP0/CPU0:Jan 31 19:31:26.694 GMT+2: pfm_node_rp[138]: %PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Clear|online_diag_rsp[9270]|System Punt/Fabric/data Path Test(0x2000004)|failure threshold is 3, (slot, NP) failed: (0/1/CPU0, 0)
Jan 31 20:31:30.841 GMT+2: 42382: RP/0/RSP0/CPU0:Jan 31 20:31:30.841 GMT+2: pfm_node_rp[138]: %PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Set|online_diag_rsp[9270]|System Punt/Fabric/data Path Test(0x2000004)|failure threshold is 3, (slot, NP) failed: (0/1/CPU0, 0)
Jan 31 20:43:42.372 GMT+2: 42383: RP/0/RSP0/CPU0:Jan 31 20:43:42.372 GMT+2: pfm_node_rp[138]: %PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Clear|online_diag_rsp[9270]|System Punt/Fabric/data Path Test(0x2000004)|failure threshold is 3, (slot, NP) failed: (0/1/CPU0, 0)
The alarms clear automatically after some minutes.
Can you give me any idea of what can cause this ans what can be done?
Aridy
02-01-2021 01:41 AM
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCus61164
M.
06-21-2023 05:40 AM
If needed, you can refer PUNT_DATA_FAILED on LSP & THMK
