01-21-2021 09:54 AM
I am looking for the 2P mounting kit for the ASR 9901 Router.
An online search yields kits for ASR 9001 and I am not sure whether these would be compatible with the ASR 9901. See link here.
Also, please explain what is the difference between the 2P-L-Kit and 2P-Kit.
Thanks.
Solved! Go to Solution.
01-21-2021 11:23 AM
i looked the URL you posted - i would be advised to Look at the 9901 racking installation and kit needed.
01-21-2021 10:15 AM
01-21-2021 10:47 AM
Thanks for the response.
Would you know if those are compatible with ASR 9901?
01-21-2021 11:01 AM
personally, i would buy from Cisco, a rather compatible one.
yes, the URL shows correct - so buy which size you want.
01-21-2021 11:07 AM
Awesome.
Unfortunately I am unable to get them locally (Nairobi, KE) from a Cisco dealer or otherwise.
Any chance you may have links to trusted Cisco dealers?
01-21-2021 11:23 AM
01-21-2021 10:44 PM
Thanks for the information and the link. Has been super helpful.
I've also got the number for Cisco global sales. I'll get in touch to have them shipped over.
Again, thanks a lot!
