ASR1000 CUBE SP syslog messages
sebastianwagner
we're trying to integrate our SBC instances (CUBE SP on ASR1000) into our network management system (EMC SMARTS)
Syslog messages from SBC instances are some kind of cumbersome with lot of line breaks resulting in multiple syslog messages the NMS must parse.
Example:
%SBC-3-MSG-6406-0006-ADD5A3-1575
Message Editor received a message with an unknown editor in
the edit sequence. The editor will be ignored.
Editor name: default
How do I configure it to just put it all into one line just as "normal" log messages?
Example:
%LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed to up
Sebastian
ngoldwat
Level 4
Level 4
thanks for replying.
I went already through this, seems I have to write some kind of script to get SBC messages into one line.
Do you have an idea for this very simple task?
Still wondering I'm the first to stimble upon it
Sebastian
