ASR1001-X, Bandwidth is exceeding the license level.
Dears,
I need to double check with you regarding the below log message:
Apr 22 12:47:38.178 JTZ: %BW_LICENSE-4-THROUGHPUT_MAX_LEVEL: F0: cpp_ha:  Average throughput rate exceeded the total licensed bandwidth 20000000000 bps and dropped 35 times, sample period 300 seconds, in last 24 hours.
Does this means that i am having high throughput that exceeds my license 20G or what?
Below you can find the "Show version" and "show license" from the Router:
MN-RT-REP-01#sh license all
License Store: Primary License Storage
StoreIndex: 0   Feature: adventerprise                     Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
StoreIndex: 1   Feature: ipsec                             Version: 1.0
License Store: Built-In License Storage
        License Type: EvalRightToUse
        License State: Inactive
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
            Period used: 0  minute  0  second
        License Priority: None
StoreIndex: 1   Feature: advipservices                     Version: 1.0
        License State: Active, Not in Use, EULA not accepted
StoreIndex: 2   Feature: avc                               Version: 1.0
StoreIndex: 3   Feature: fwnat_red                         Version: 1.0
StoreIndex: 4   Feature: ipsec                             Version: 1.0
StoreIndex: 5   Feature: lawful_intr                       Version: 1.0
StoreIndex: 6   Feature: lisp                              Version: 1.0
StoreIndex: 7   Feature: otv                               Version: 1.0
StoreIndex: 8   Feature: sw_redundancy                     Version: 1.0
StoreIndex: 9   Feature: throughput_5g                     Version: 1.0
StoreIndex: 10  Feature: throughput_10g                    Version: 1.0
StoreIndex: 11  Feature: throughput_20g                    Version: 1.0
        License Type: RightToUse
        License Priority: Low
StoreIndex: 12  Feature: vpls                              Version: 1.0
StoreIndex: 13  Feature: interface_10g                     Version: 1.0
        License State: Active, Not in Use, EULA accepted
            Evaluation period left: 8  weeks 3  days
            Period used: 1  minute  5  seconds
        License Count: 0/0  (In-use/Violation)
MN-RT-REP-01# sh ver
Cisco IOS XE Software, Version 03.12.00a.S - Standard Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(2)S0a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Tue 13-May-14 18:36 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
MN-RT-REP-01 uptime is 22 weeks, 5 days, 46 minutes
Uptime for this control processor is 22 weeks, 5 days, 47 minutes
System returned to ROM by reload
System restarted at 11:46:58 JTZ Fri Nov 14 2014
System image file is "bootflash:/asr1001x-universalk9.03.12.00a.S.154-2.S0a-std.SPA.b"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: adventerprise
Next reload license Level: adventerprise
cisco ASR1001-X (1NG) processor with 3765392K/6147K bytes of memory.
Processor board ID FXS1834Q2EE
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6688767K bytes of eUSB flash at bootflash:.
Muhannad
flettster
Hi Muhannad,
Sounds like it. Looks like you can do:
show platform hardware throughput level
This reads like 20G is the limit as well.
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/1001-x/asr1hig/asr1lic.html#pgfId-1060881
Dears,
It was cosmetic error message.
The matching bug ID:
CSCup32534 Nightster- Crypto throughput threshold messaging changes and errorCSCul78115 Incorrect notification of BW_LICENSE-4-THROUGHPUT_MAX_LEVEL messages
Fix for this bug is in 15.5(1)S <3.14.1S> and later releases.
Muhannad
Seeing the below bug even in higher releases 15.5(3)S4b <03.16.04b.S>
%BW_LICENSE-4-THROUGHPUT_MAX_LEVEL: SIP1: cpp_ha:  Average throughput rate approached the licensed bandwidth of 100000000 bps during 18 sampling periods in the last 24 hours, the sampling period is 300 seconds
Any solution? I would like to know the impact of this bug.
Could anyone help me out? Thanks
Cheers
antonkolev
Did you find a Cisco  MIB to monitor  throughput level on the router  ?
