ASR1001-x Layer-3 (VPNv4) MPLS & Netflow
Oerlikon_NZ
Hi folks
Using flexible network, I'm trying to collect netflow data for vrf traffic on routers that are part of a layer-3 MPLS network.  This is on Cisco ASR1001-x routers with advanced IP services.
See attached diagram.  I am trying to collect netflow data 'A' within the VPNv4 MPLS core & 'B' at the edge.  When I enable flexible netflow (input or output) at A, the only netflow traffic I capture is for underlying Layer-3 IBGP & IGP.  When I enable flexible netflow at B, I see inter-site netflow traffic for vrf #A  & vrf B hosts.  What do I need to do to be able to capture this data within the MPLS core?
Sample config SITE 1
flow record FNFRecord
 match ipv4 tos
 match ipv4 dscp
 match ipv4 protocol
 match ipv4 source address
 match ipv4 destination address
 match transport source-port
 match transport destination-port
 match interface input
 collect interface output
 collect timestamp absolute first
 collect timestamp absolute last
flow monitor FNFMonitor
 record FNFRecord
interface GigabitEthernet0/0/1.*
 description -> Site 2
 encapsulation dot1Q *
 ip address *
 ip flow monitor FNFMonitor input
 mpls ip
interface GigabitEthernet0/0/2.*
 description -> Site 3
 ip address *
 mpls ip
interface GigabitEthernet0/0/3.*
 description -> LAN VRF 'A'
 ip vrf forwarding A
 ip address *
 description -> LAN VRF 'B'
 ip vrf forwarding B
 ip address *
Thanks in advance.
Oerlikon_NZ
*bump*
