WEB FILTERING
oyenibi4lv
Visitor
Hi all,
I have a 3845 cisco router, i need to block access to sites such as facebook, youtube on the router itself while allowing the executive to have access to these sites. I dont have a firewall for now, can this be achieved on the router. command line will be appreciated. 192.168.20.0 is y LAN ip.
zdesignstudio
Level 8
Level 8
Here is a decent how-to.
http://www.techrepublic.com/article/block-access-to-a-web-site-using-the-cisco-ios/
Please rate useful posts and mark answers as correct if applicable.
Kias
Level 3
Level 3
As its HTTPS inpection, you need to integrate a content filter of cisco or other vendors. Also you could build your open source squid-cache proxy and intercept SSL traffic on physical or virtual machine. This helps you to customise URL blocking policies for HTTP and HTTPs sites. The machine is connected via WCCP to the router.
Kias
Fonicom Limited
raiseaticket Malta
Mark Elsen
  - Whilst a valid request , in the IoT age, the problem becomes 'broadened' and may need a wider philosopy approach. For instance ; we don't block facebook , because it would probably need to a 30% company productivity loss, as people would perhaps be more watching their smartphone then their PC. In that context, additional solutions can be implemented related to MDM enforcing products :
https://en.wikipedia.org/wiki/Mobile_device_management
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
