Hi all,
We are about to migrate all our ASR9K P routers from RSP440 (IOS 6.0.2) to RSP5 (eIOS 6.5.3).
To ease migrations, we would like to keep console port speed at 9600 bds. Do you know if this is possible, and, if yes, how to do this ?
Thanks a lot.
- I would presume that the console port-speed will not be changed by default.
M.
That's why we are looking for a configuration to change console port-speed. With RSP440, it was feasible with config-register modifications, but with RSP5 and eIOS 64bits we did not find config-register commands.
