ASR9K RSP5 console port speed
Hi all,
We are about to migrate all our ASR9K P routers from RSP440 (IOS 6.0.2) to RSP5 (eIOS 6.5.3).
To ease migrations, we would like to keep console port speed at 9600 bds. Do you know if this is possible, and, if yes, how to do this ?
Thanks a lot.
marce1000
 - I would presume that the console port-speed will not be changed by default.
 M.
That's why we are looking for a configuration to change console port-speed. With RSP440, it was feasible with config-register modifications, but with RSP5 and eIOS 64bits we did not find config-register commands.
vijaypandey8982
hi,
i am also planning to do migration from rsp 440 to rsp5 do you have any document which refers to this migration smoothly?
