Assign each physical port a unique static IP for CBS250-16T-2G
SithLordVader
Is is possible to assign each physical port of a CBS250-16T-2G a unique static IP?
pieterh
using the GUI, change to L3 mode first
Click VLAN Management > Interface Settings.
Step 2 Select an interface type (Port or LAG), and click Go. Ports or LAGs and their VLAN parameters are displayed.
Step 3 To configure a Port or LAG, select it and click Edit.
Step 4 Enter the values for the following fields:
Interface Select a Port/LAG.
Switchport Mode Select either Layer 2 or Layer 3.
then assign ip-address
Step 1 Click IPv4 Configuration > IPv4 Interface.
Enter the following fields:
• IPv4 Routing—Check the Enable box to enable IPv4 routing (enabled by default).
Step 2 Click Apply. The parameter is saved to the Running Configuration file.
5 Replies 5
pieterh
what do you intend to achieve with this ?
but yes it can
Cisco Business switches 250 Series CLI Guide - VLAN Commands [Cisco Business 250 Series Smart Switches] - Cisco
switchport
Use the switchport Interface Configuration mode command to put an interface that is in Layer 3 mode into Layer 2 mode. Use the no form of this command to put an interface in Layer 3 mode.
in Layer 3 mode you can assign an IP-address to the interface
each port is wired to an instrument for a specific test site and we need to be able to switch out instruments for calibration without changing the test site. I was trying to achieve this through the web interface to no avail so I will have to read up on the switchport commands to get this working. thanks for the response!
pieterh
SithLordVader
awesome, this is perfect, thanks so much for your help!
You are welcome,
thank you for marking my post as helpful/answer
